Recently stripped my carburettors and replaced the o-rings, diaphragms, gaskets and generally clean out all the dirt. Asked around for information how to reset the carbs and get it to start easier. The general feedback was set the butterflies/throttle control so that you can see exactly the same amount of light when holding them up filtering through? Turn the air/idling screws out about 1 1/2 to 1 3/4 turns. Once they are fitted back on the bike adjust the idling by turning the air/idling roughly the same amount in or out until it idles. Use vacuum gauges or carbtune to balance the carbs?
Now once the gauges or whatever I will use to balance them is on which screws do you turn to balance the carbs? The throttle control screws or the air screws? I have not touch the throttle screws since resetting them and only adjusted the air screws to get the bike to idle but will get around the balancing during the week once I have more information regarding the setting of the carbs. It runs fine at the moment and not stalling or backfiring so think it is pretty close to what it should be however it still does not start easily in the morning and the moment I touch the throttle it takes longer so my guess is it might be getting too much fuel and flooding?
Any comments, ideas and suggestions as always very welcome.
