Corrosion Block Grease is designed to provide maximum protection under severe conditions. Its formulation provides both high and low temperature performance, increasing the service life of critical components.
Corrosion Block Grease strongly resists water wash out and provides superior protection against rust and corrosion. Corrosion Block Grease outperforms lithium and most synthetic greases and meets or exceeds requirements for NLGI Service Classification GC-LB (automotive wheel bearing and chassis lubricants), which is based on ASTM D4950 performance requirements.
BENEFITS
Protects heavily loaded equipment, and extends bearing life
Resists running, bleeding and softening at high temperatures
Suitable for extended periods of operation at elevated temperatures, and sealed for life applications
Use in electrical applications that require grease
Workplace safe and environmentally friendly
Won't soften, breakdown, or wash out in wet applications
Suitable for use in centralized lubrication systems and low temperature environments
Easy conversion with no cross contamination concerns
Easy to identify, high visibility
FEATURES
Excellent extreme pressure (EP) properties
Excellent thermal stability
Outstanding oxidative stability
Non conductive / dielectric
Contains no heavy metals or environmentally objectionable materials
Superior corrosion protection and salt water resistance
Outstanding low temperature mobility
Compatible with most grease types
Distinctive Aqua colour
APPLICATIONS
All purpose chassis lube, parts lubricant, bearing grease, battery terminals, gear regulators & tracks, linkages, hinges and locks, hubs, axles, springs, wiring harnesses, CV joints and much more...
