Shez_ow01
Not breaking out the champagne yet but that was a ride roughly 6 x as far as I have been before without a glitch, I have thought I had cured it before but that was after a few miles test ride not a long one like this.
Spent the last 30 miles doing all the things to try and provoke it, low RPM closing the throttle then slowly opening it again sitting in traffic etc.
Not even a stutter. and with all the really fine setting I have been doing to the throttle bodies/TPS it is running gorgeously now.
Found the short in the Lambda sensor wiring, must have been resting against the exhaust and the really hot day which started all of this was just too much for it, ever such a slight bit of damage to the insulation on two wires where they rest against each other, they don't touch all the time so that would cause the intermittent affect.
I have ordered a new Lambda sensor hopefully then all will be back to normal.
The gs911 is a superb device, straight away told me the error codes.
I have replaced some parts which I didn't need to;
Hall sensors I only replaced the sensors so they cost me about 20 UKP
Coil that was about 50 UKP
The following I don't consider a waste
HT leads, well it is always good to have spares I have had them go before on this thing.
Plugs are a service item
Throttle cables - they were looking frayed.
I have also ordered and am awaiting a ignition switch wire, but that seems to be only a matter of time until I need it anyway so I am doing that sooner rather than getting stuck.
Might put a couple of hundred on it tomorrow just to be sure.
Shez
Shez
