Shez_ow01
Hi all,
My 1150gs has started cutting out and I can't get to the bottom of it;
Symptoms are the bike will cut out for no apparent reason and there is no pattern to it, Pull in the clutch press the starter and it fires up again. It has happened at high speed, low speed whilst slowing and whilst accelerating.
It started about a week ago I made the fatal mistake of washing the bike, last time I washed it was about 6 months ago and it cost me 500 quid in diagnostics and hall sensors. Then I vowed never to wash it again but I had too it was stinking
The next day the bike ran fine except the gear indicator was all over the place, but that day there was really bad traffic heading into London so the bike got very hot (two bars from the top) the bike didn't cut out at all on the way into town, however coming home it started to cut out, as I said it would start again immediately but the journey home (approx 50 miles) was fraught as it cut out over 20 times.
I have not really used the bike since then, have tried smothering it with WD40 in all the joints in case water got in and I have concentrated on the sidestand switch as that seemed likely, but it is still the same, only clear indication is from cold start it is fine for a couple of miles then it starts cutting out.
Any ideas? I hope it isn't hall sensors again.
TIA
Shez
TIA
Shez
