Okay so there has been much talk of the "new" method, it has actually been around for quite a while!
I can claim no credit for this procedure and my apologies for schite photos it wasn't meant to be a process I just figured (when I was halfway through removing one for a mate) it was time folks stopped cutting their wiring looms and causing themselves grief
Why use it over the original first post ?? Okay whilst I did use that method a couple of times and it is fine it leaves a weak point in the wiring
Its "basically" the same process for any of the bikes with servo ABS the 1200 Hexhead bikes have no blue relay to "pull" and the GS has surface mount LED for warning lights so all you do is remove bulbs from the panels (or in the GS case paint the LED with black nail polish and/or the warning indicator cut out )
Its simple I snip the pipes with a decent pair of diagonal cutters Basically it seals the pipes and prevents fluid spillage as you lift the unit out
the electronics plug is removed by extending the slide lock and lifting up Careful you need this to refit so don't break it!
This is the bit that you need I cut the wires already I very much doubt anyone will ever have enough money to refit the ABS pump section and fear that they "might" wear through on components in the electronics You could fill the box with silicone and embed them Basically whatever floats your boat!
the are 4 connections from the electronics box and two from the ABS unit
A standard UK front or rear number plate cut to length is almost perfect for sealing the electronics box up
