Mr K
If this doesn't prompt Tarka to post, nothing will.
Defo wider and I'm looking forward to how you're gonna get the triangulation on the mounts as I'm scratching my head here.............
Andres
PS Another vote for your bike in red (even if it is an 1150)
Bill That's an awful lot of weight swinging on that "long" bit of angle I think i'd be considering beefing it up by stitching a length of tube either at the back or better still a quadrant of plate (maybe with a Wheel cutout (if needed) and big holes for lightness / strength) across to the other side of the frame ???
Reading it again Bill a quadrant of even 6mm plate up under the exhaust would make a nice feature of the strengthener rather than a dod of tube?
Hey Bill,
It's great to see a hack build underway, and to see Paul's finally seen the light and got a sidecar section together However I don't want to spoil your fun, But......
The sidecar chassis you have there is a Velorex and is from the 350/250 Jawa, MZ or CZ's. As you will know these are very light bikes and they where made in a country that doesn't have too much concern for quality of materials.
The big problem, (bearing in mind the weight of the 1100 and consequently the extra forces you'll be putting through it) is that the metal tubing is not thick enough or good enough quality for the job your asking it to do.
If you really want to stick with the present chassis 'even though it's got to be easier to make one from scratch' I'd suggest you add lots of extra strength (gussets etc). Especially to the joints, plus beefing up the tubing.
I know you've mentioned looking for another wheel, but the axle will need to be upgraded too. It has a very small 15mm axle fitted which won't be strong enough (and is prone to braking) to hold the weight of the 1100. On the plus side the new version of said chair has a 20mm axle. so you might be able to get a replacement. F2 sells them.
You mentioned Mr Cob earlier. So you know of the Hacks section on the Adventure site. Do a search in there for builds for the 1100s there's quite a few and with plenty of pictures showing how they did the mountings. That place is definitely your friend where this is concerned.
As it happens I have the same chassis and chair (though the axle at least has been modified and the wheel matched to the bike) on my R80. It works quite well on the old girl, but it's bloody light, to the point of being scary. Without 20Kg of ballast it's virtually unridable solo. The Airheads are about the heaviest bike you can fit these to 'and get away with it' and then you wouldn't want to push it too much. Right hand bends put an enormous amount of weight and force into that pathetically under designed chassis and axle.
Sorry to blow holes in your pie, but thought you should know before you get too much further.
Val.
.....This has all the makings of a new Channel 5 series
We are going to be reinforcing it a LOT, and we are looking for a new wheel/axle assembly...
I'm now beginning to see the reason for Type Approval laws......
That's my only imput so far,apart from it's absolutley hideous,built completley wrong by a feckin monkey,and welded by a blindfolded blind man in the dark,and certainly doomed to failure causing one or more deaths in the surrounding area.GOOD EFFORT,CARRY ON
