Just going back through this to make sure I've taken everything on board
Thanks Vern.....that 'mounting point' isn't actually going to be structural- It was more there initially just for lining stuff up and setting up the chair frame on the bench- the bit of rod poked through into it in one of the early pics was just that, an alignment tool.
That point sits in a triangle of space that is probably going to be needed for paddling the thing backwards or holding it on inclines, so I doubt there will be anything at all there in the finished version
We ordered 6 welding bends in 38mm thick wall tubing today...should get them tomorrow, then we can get on with thinking about considering how to go about planning how to build the cage that will go on top (and strengthen) the Velorex frame.
I've been scouring all the Ebay ads and bike wreckers for a single sided swing arm assembly from something that had a bit of power....I've done a 3d CAD drawing of a single sided swingarm in a frame cage, but also a double sided jobby (plenty around for around the 50 quid mark) that looks seriously do-able.
The original axle and wheel have been pretty much mentally written off now, and we've been through every type and grade of Indespension unit online to see if we like those......A nice aluminium double or single sided swing arm with a really solid shock mount bracket feels like the way to go....ideally, one with a fitted disc or maybe even disc, caliper and wheel
