Kinnell !!!. Ive just spotted this. Hope the poor chap makes a quick and full recovery. He's a great advert for adequate health/accident insurance.
Well, as it was nearly 5 years ago, let's hope he's fully mended by now !!
Until someone keeps "checking" the bolts until they break. If they are torque wrench checked each time, the screws will gradually tighten until the inevitable happens.
Is this correct? I checked mine and torqued correctly. Are you saying each time they are re-torqued that they weaken?. I don’t think BMW use loctite when installing them and I’d read using any substance on the threads could mean that when you tighten them and torque them, it means they are over tightened due to ‘slipage’.
Surely it is the alloy drive shaft casing that is the greater concern? At 24Nm torque I find it very hard to imagine the bolts failing.
The situation I’m using as an example was Willington Power Station near Derby. About two years after each unit was started up.....
That must have been a long time ago, it was decommissioned in 1999, I used to drive by it most weeks, only the cooling towers left last time I looked.
Was it ever established if the bolts just came loose through copperslip etc, or simply because they were not bolted in properly after a tyre change?
Back wheel removal doesn’t affect the back brake. But I doubt we we’ll ever know why his caliper rammed itself into the wheel.
Ahhh! Not done a rear wheel on the 12 yet. I was thinking the caliper came off like on the vintage bikes.
It’s like a car wheel for fitment but always use a torque wrench when refitting and tighten evenly.
