Probably an hour to fit and that is taking your time, of course it does help if you put it in the correct way round
Yes but how much and where to get!
Oy Yeah it's obvious which way round the chip go's when you open your eyes I fitted several in the past but had a momentary lapse of memory and common sense
Timmo, whatever made you think I was referring to you
Was your clutch slipping with the stock chip then?
No. It's not slipping now either. To achieve 70mph requires less revs that's all.
Perhaps you'd like to describe how that is possible?
Ok. Well, I don't know really but doing 70 mph on the motor way the rev counter was 4-500 rpm lower than it was the week before. Treble digit speeds not a problem. Bike was never happy above 90 before.
I'm very very pleased.
Your bike is doing exactly the same speed per rpm in each gear as it was last week - unless you've changed the gearbox or final drive...
Mike,I fear you will suffer a nasty headache if you persist in banging it against the wall.It's not a variable...
