So looking at the pictures, the friction surface is now between the new pivot pins and the bronze bearing surface. Is that how you guys see it? So that is a smaller surface area is it not? with a greater loading factor.
How can it be loading onto a smaller surface area, even needle bearings have tiny contact points?
You are right comparing standard bearings to these. I was thinking about those 'rubber chicken' bearings, which are of a similar design, though have a larger bearing surface but less lubrication. Seams they have also been failing.
Should have made myself clearer. Sorry
I fitted a set last week to a punters bike.Well made and do the job and you can bang them full of grease whenever you want to.Miles better than needle bearings.
That's all you need to know isn't it?
Right,I'm off again and leave you lot to discuss utter bollox without having even seen them.
Just bought a set for my newest 11GS and even with a bit of trade discount BMW still charge nearly £60+vat... It's almost laughable that all those years ago BM managed to patent this pissy sized bearing... Normally sourced they would be 1/4 of that at the most...
Using appropriate grease makes a huge difference.
Thixo grease is good for applications like this.
Using Thixo on helicopter rotor hubs and it is doing a great job
they didn't patent it. they just used a non standard, or commonly used size. they are available from other sources, but IME at more than double the bmw price.
