i have read the sticky on 1150gs removal,potentially looking at a r1150rt to buy with failed abs,is the servo/abs removal on 1150rt the same please.
thankyou,much appreciated.Have look at Chris Harris video on YouTube on r1150rt abs removal
http://m.youtube.com/watch?v=7xZMewBazMI
I wouldn't take any notice of that video. It's a dogs dinner unprofessional way to remove the servo.
There is no need to cut any of the wiring loom. Just undo the small servo ecu at the end of the servo/abs modulator (4 screws) and plug it back into the loom That way it can be returned to servo/abs at any time in the future. Plus you're left with a lot neater wiring without the chance of any future grief from the electrics.
Hi Steptoe
That looks a much better way of doing things - my question is how do you re-route etc the actual brake lines (has anyone done a guide for this ?)
Many thanks
Golfy
Its simple!
up at the right hand side of the headstock there is a twin tube arrangement where the brake pipes "meet"
the steel pipes from the rear of this are redundant
and you just need to connect the two front pipes or get a small brake pipe made to go between both rear bits
You do the same sort of thing at the back you just connect the master cylinder to the calliper with an unbroken length of brake pipe / flexible hose
Bleed the brakes and Before MOT remove the front sensor and the inner disc it no longer Looks Like an ABS bike
I've recently done this on my GS1150 but I also upgraded the Brake Lines to Braided whilst I had everything apart.Much appreciated, will give this a go when I take out the ABS servo . It also looks like Motoworks do a bit that covers joining the front pipes.
Presumably this also means that bleeding the system will be a whole lot easier as well
Many thanks]
Golfy
Hi allI've recently done this on my GS1150 but I also upgraded the Brake Lines to Braided whilst I had everything apart.
I didn't use anything from MotoWorks for the Conversion though, didn't need anything.
They do supply a Kit of sorts but it includes new Brake Light Switches at £35 a pop and you don't need them if you use Steptoe's Method.
