Danzio
Riding along perfectly well and got a huge backfire from the exhaust which then killed the engine and the bike stopped.
By the roadside for a good 3 hours checking various things.
Checked stick coils (which are brand new) plugs, all good (including a spark test on both sides against the frame). battery was all good. connections and side stand switch working all as they should.
Tried multiple times to then turn it over, and the engine sounds good, no abnormal noises, and it cranks fine with what seems like decent pressure... but it just won't fire.
When i'm trying to turn it over it keeps backfiring slightly (fuelling issue?)
The battery has obviously taken some hammer when trying to repeatedly turn it over and so when trying now the clock resets. (including that info in-case its relevant.)
Only had the bike 4 weeks and done 400 miles... Gutted, as its such a lovely example.
Any help will be greatly appreciated. I did try looking on various forums but not found anything specific to my needs.
Cheers guys.
Cheers guys.
