Because they can seize beyond lubrication. In my case the bolts snapped! complete new header pipes fitted
Drill out the snapped bolts, can't you ?
You can actually take out a new warranty if your old one has lapsed. This didn't used to be the case and I think it costs a bit more, but you might be able to do this and then suddenly find the problem
So what's the best way to prevent the failure? What would be the best lube to use to keep the fecker working right?
Nickelslip has a temperature rating of up to 1350C
http://www.draketooling.co.uk/Products/maintenance_workshop_anti-sieze/MOL18A005 is the cheapest I've seen it
It stays closed at low revs to improve the torque delivery at low revs and open up at higher revs to aid power delivery. This is how it was explained to me, is it true, i do not know.
Just to add my 50 pence worth. Mine was changed by Chandlers after I took the bike in for a quick check as it was stalling occasionally. (another thread somewhere) They found my flap was seized that was after 7000 miles on a 2013 GS. I hadn't noticed... Not related to stalling either. Replace all exhaust, nice new headers etc. Will now keep lubed as per above as the 2 years (warranty) is/are up in a fortnight. Will extend warranty though to be in safe side. Still makes me smile 2 years and 10k miles on....!!!
Sorry to be a noob but what does the flap do?
Issue is, it's not covered by the extended warranty though. Mine has just failed just outside the warranty. Not covered.
Secondly BMW sell, and we buy on the basis of quality product. If even the dealers are suggetsing there is a quality issue and 'theyre not as good as they used to be' then it's an problem.
Exhaust flap on my '16 GS was squeaking every time I turned the ignition on. Got the local dealership to investigate it just before the 2 year warranty expired - ended up with a completely new set of headers as the flap was totally seized. Outside of warranty it would have been a €1500 fix so dodged a bullet there. Opted for the extended warranty recently, but the cover doesn't extend to the same degree as the original warranty (exhaust flap being one example).
