Water leak...
Camel Toe
Sheffield, England
Guys a friend of mine has a 2002 650 which is leaking water from what appears to be a hole in the water pump casing... any ideas....
so easy to do
Even I managed to sort this one, only headache was when removing the clutch cover to remove the oil pipe to the top end, cut it in 2 and seal with a std compression fitting.
