This has me a bit stumped
Needing to update some maps and of course the memory isn't large enough on the Nav 5 so the maps need top go to the memory card that is and always has been in the device.
Garmin express can't find the card ???
So
I am using a mac
The card is 16GB and formatted to fat 32
It has music on it which plays and there is about 14GB of spare space on it !
Any ideas ???
I had the same problem on my 660 Rick (same device I think?). I eventually bought a top spec 32gb card and fitted that. Since then all's been good.
Andres
Different devices, fundamentally different in many areas, I'm afraid. Same problem though.
this seems to be a common problem of late, i cant comment about a fix as i use a pc, do you have a card reader and if so can you see the card using it. and if you can use that and instal maps to it.
As above, this seems to be a problem for some users of late.
If it helps, which it probably doesn't....
I use a Mac, running BaseCamp. I have a Nav V, with a 16 GB card in it but with no music on it. Yesterday I sent OSM maps of the whole of Germany and chunk of the Benelux (something like 92 individual tiles and 2 gb of data) from BaseCamp to the SD card
using Map Installer. It worked perfectly. BaseCamp / Map Installer sees the card (and everything on it) perfectly, each and every time. All my software is up to date.
As I type, I am sending the same OSM maps to a second Nav V, set up identically, again without a problem.
From what we have been told, the only real differences that I can see between the OP and my set-up are
(a) The difference in the card size; that shouldn't make a difference.
(b) He has
music * on his card, I don't. Post 2 mentions music (or the removal of music) as a cause / cure.... Try that.
(c) He is doing something in Garmin Express, whilst I used
Map Installer
* Music and comm's are the source of much angst on these GPS pages.... I am glad that I avoid both
