charging
DC
can the 9T Battery be charged through the accessory socket with the correct optimate lead ( like the RT and GSA ) ?
Charging
I use it with the BMW Charger so I cant see why it would not work with the optimate:thumb2
Surely the CanBus would shut the electrical system down like it does on other newer BMWs ?
On my old 06 GSA I had the Optimate lead hard wired direct to the battery :thumb2
That's half right! But on the RT LC if you connect the charger to the bikes accessory socket with ten mins of switching it off at the ignition , the socket takes the adapter and charges the bike . I was hoping it would be the same for the R9 too , sounds like it is
