You need to fiddle about adjusting the screw, ref 1, so that the pannier sits down on the mounts properly.
sproggy, would you have an specific measurement recommended by that manual?
It appears that X=30mm. One of mine is about 29 and the other about 31 so I guess there's a bit of tolerance.
They're intended to accept the top hanging points of the Vario panniers.Excuse the slight hijack but your thread reminded me of a question i have. Is there any actual purpose to the slots on the back that i use to bungie things to the back of my bike? or are they just that, points to attach stuff with bungi cords?!
Yes, as Greenman says you'll need to do some fiddling You need the screw low enough so that the weight of the pannier is taken on the hanging tabs on the pannier, not on the adjusting screw, but high enough that the lock mechanism will function properly so that the pannier is retained securely. When you've got them just right you'll find the pannier will need a bit of a wobbling around to get it to seat correctly, then will be solid when locked on, even maybe needing a slight downward pressure to engage the lock mechanism.
You shouldn't need threadlock as they have locking nuts on them.
