fredaroony
I got this to power extra accessories like phones and my two GoPros. It gives you 5 circuits switched 12 volts with a maximum of 5 amps per circuit. If you need more than this then you will need a use a relay or another device.
I liked this because it's water and dust proof plus it's very cheap. The full details can be found here http://www.innovv.com/innovv-power-hub1-cjxt
The leads to the battery were far too short so I needed to buy extra wire to lengthen the cables. I also added superseal connectors on four of the leads and a SAE connector on the last one. You get a single ground lead and I tied all 5 grounds to this single lead.
I used the rear tail light feed for the trigger wire.
The unit fits absolutely perfectly under the tail section on my 2016 GS.
The device out of the box
Taps and battery terminals
