KP100
Thanks for the link..
Just bought a set.
Just bought a set.
Yeah, I'm expecting to have to fiddle around with the install. I'm considering running the main beam bulb without the heat sink as it won't be lit for long periods.The bulb back end is much bigger than the old halogen the heat sink will probably catch the access hole in rear of headlight. Be careful to not dislodge the beam level adjuster. It's a plastic ball & socket and does pop out.
I turned down my heat sinks to give a bit more clearance taking the tapered shape to parallel.
Sent somehow.
Don't know....I just looked on eBay and some guy had 3 for sale for £4.99 eachThose rear caps you got. Does any other model share the same part? Like the RT and so one?
Good idea to get a couple of spares.
I'm aiming to keep the original connector and covers intact so I can put it back to standard if I need to. Probably have to make up some patch leads to allow a neat job.
Oneplus 2 = my phone
I've got the same, albeit the H4 version in my R Nine T, the Heatsinks are reversible to. Mine were sold as Phillips Luxeon, and the emitters are branded but the rest is probably the usual chinese effort. A single H4 works very well though, I reversed the heatsink to make it fit more easily in the headlight bowl of the 9T and so far, so good. Beam cut off's look almost identical to the H4 Halogen it replaced, and quality wise, no issues as of yet.
This was my kit http://www.ebay.co.uk/itm/H4-LED-Ph...lamp-Bulb-Light-6500K-Lumileds-/182449459475? Cheaper than the Cyclops, and gives me a spare
I have not had that problem, low beam cut off is good.
Also had it double checked when it was MOT`d , although not necessary as the chap that does the mot`s is very thorough.
