hogfarmer - great news albeit I'm deeply jealous!
Squibb - I think I shorted out the side stand switch at the plug (joined 2 of the 3 wires (not the red one from memory)). Clutch switch ... any clues as to what to do/look at with this one.
I also have just checked that there's 12+V at the BMS relay going in to it, and then out of it.
Should I buy some replacement relays just to check?
Aghhhhhhhhhhhh!
If you check the diagrams from the link in post 10, page 4 it clearly shows the correct scenario - it's a complex system, linking the live from the ignition to the neutral light switch from the gearbox, to the clutch, sidestand & kill switch. A failure in any one of these elements could kill the ignition. The clutch switch is just a case of removal & jump the leads to give the appearance of the clutch lever being actuated/pulled back to the bars. However, my money is on the sidestand switch, which is more complicated than it first appears & prone to internal corrosion.
Incidentally, were there any issues historically, when the bike was in use regularly?
