ross.
It's simply a switched power feed added by someone as smelly old boots has said. Remove it or keep it for future use.
yes it does look a bit diy i will try and trace it see where it goes
took the pump out of the tank today, the tank was full of crap floating about, dosen't look like the liner but plenty of other bits
in there
New fuel filter for sure then.
Have a close look at the big round seal, if no damage you might get away with re-using it ok.
i have a new seal in the service kit i bought from motobins. and ideal what i could use to wash the tank out?
Fresh petrol?
That way you know there'd wouldn't be another contaminant in there
Mart
Kabooom
Seriously,if you have ever seen a petrol fire you wouldn't be recommending this.
Remove the pump mounting plate and the filler cap/neck etc,
Just gently pressure wash it out,
You can then mop up excess water though the pump aperture,and pop in the sun or somewhere warm to dry.
If the red painted liner is flaking off you will need to be a bit more aggressive with the cleaning,I use high pressure steam to remove the old lining paint if it's really shoddy.
Incidentally if the pump mounting studs shear off,don't panic they can be replaced
Why would there be a fire risk if all he does is use a half litre or so of clean fuel to swill out the tank
What a stupid thing to say,
I feel sure that the many people maimed or badly burned through fucking about with petrol thought they were far to clever to have an accident,
Why risk it???
Best just carry on then,
What do I know about such things
Seriously. I'd like you explain the in's and out's of it.
