commandoallan
The open circuit that is referred to above is talking about a break in the circuit in the sensor (a bit like if you run over the flex with your lawnmower and cut the wire).
The ZFE is the computer trickery bit that takes the signal from the fuel sensor and sends it to the gauge.
It is possible that the ZFE is FUBAR, but I don't recall seeing many cases of them going wrong on here, and I would not have thought that such a complicated component would have a fault that manifests as a simple open circuit (not that I know anything at all about the test procedure for the ZFE, so this is conjecture on my behalf based on attempts to fault diagnose similar things!).
At that potential cost is there somewhere you can go for a second opinion?
Red Evo.
I suggest you read most of this chain. The item you refer too is indeed an option for most to consider. I have sourced the float and am in the process of ordering the converter from Henk. In your case if it is the ZFE I think you will need to confirm if this is after the converter that Henk sells (as I believe it should be) and if the fuel level float can still function through the converter into the gauge without a functioning ZFE which presumably stays in the circuit.
Does that make sense to anyone other than me???? I think I may have confused myself so will retire with a beer.
