MWH
Thanks, my strip is working every now and then. May go the conversion route and just hope the strip decides to be in working mode when I try and calibrate it!
I would do it sooner rather than later, as you will need a strip otherwise!Thanks, my strip is working every now and then. May go the conversion route and just hope the strip decides to be in working mode when I try and calibrate it!
I was presuming that you calibrate at dry its therefore "empty" regardless?.....dodgy fuel strip calibration?
The float system has been in place about 6 to 8 months now and it reads a little off, it tells me I am empty after about 200 miles when in fact I can go at least another 100
From what I understand, the fuel strip either works or it doesn't, if it fails, it fails "empty" rather than full.
Doh. Got the float today, thought I'd get stuff ready by fitting the float to the pump. Bit to late as my strip won't calibrate! Thought if I could've got that done I could've reassembled it all ready and just need to plug in the converter!
My issues in a different area. I can't get a known working fuel sensor strip to calibrate.Malvern Beemer is having a similar problem I believe.
I used a brand new float - so that removed any doubt in that area.
