There is not a general problem, more of a quality control problem with the software built into the shock. When the software fails it tends to fail at one end of the damping range or the other, so it can become harsh, or as mine did, become very soft damping, the preload on mine also failed, going out of callibration.
That the shock can be recallibrated shows that the mechanical side of things still works till the ESA Unit software on the shock goes awol again, eventually failing to reset completely.
The bike is not unrideable, but, very unpleasant to ride bordering on dangerous through loss of traction through being very over or under damped. Mine failed when on a trip in France, I had to set the preload to rider plus luggage and the damping to hard and I was still getting the pegs down, I only weigh 11.5 stone.
The 2017 ESA has different setting with, I am guessing, the same shock.
