fredaroony
Are you downloading the content from the SD while still in the camera? If so, I would recommend getting a SD card USB adapter to read it directly as it should be much faster
But - are you wiping the SD card each time, or are you just downloading that particular day's footage and allowing the camera to overwrite the next day? If you are overwriting, then the less times you take the sd card in and out - may prolong the life of the slot in the camera?
That said - perhaps the socket for downloading might be equally susceptible to wear.
al
Its the Wi-fi within your own house that will limit speeds.
My Broadband speed is reasonably fast at 20MB upload, so can't complain to much about that either.
Yes, it is reasonably fast, but always remember that Mbps is Megabits (Mb) per seconds, not Megabytes (MB).
Also, that is your upload capacity. It doesn't mean the server on the other hand will always match that speed, depending on what/who you are using.
I randomly read a few things here and there in this thread, but out of curiosity, how can it take you 10 hours to download a 50 mintes 1080p video connecting to the camera via (presumably) USB cable (assuming USB2 connection)?
How big is the file?
- For a 50 minute YouTube clip it takes around 10 hours to download and render it all. I currently have to download each camera footage separately (which can take about 1 hour each if the cards are full), then it 'optimises' which can take up to 2 hours, then I can create the video. Then it has to be rendered which can take hours. Then it has to be uploaded to YouTube which takes around 3 hours on a 20Mb upload speed.
Ah, ok, I initially misread.
I assumed 10 hours for download and processing only! That seemed a lot.
This is still a lot, but makes more sense now.
Sorry - I assumed you were using wifi .
Al
I'm not going on exact time's as its way to long to actually time it. Bit it is HOURS
Frickin 12 hours of my life gone, just to get one 50 minute video out.
Of course, it makes sense now.
Initially I misunderstood and assumed it took you up to ten hours just to download and automatically process 50 minutes of uncut video footage. That was a bit too much and was trying to troubleshoot where the problem might have been. But as you explained it, the time it takes sort of makes sense.
And almost no one is watching 50 minutes of road riding.
No one is watching 3 minutes of someone skydiving these days: rule of thumb, keep it short and sweet
I kept reading over your set-up as the work done is very interesting... my two cents: unless I got it wrong again, if you are recording 60fps on the front and 30fps on the rear, you basically waste rendering time re-adjusting the fps to 30 when you do the final edit. You can shave some minutes/hours there.
Except my elderly Mum... haha, and the lads on the ride who just want to watch themselves on the TV
Ok now that is useful, because the front camera is recording at 60 fps, and the rear only has 30 fps at 1080p. So I might just set the front up at 30 fps then if it gets produced at the lowest common frame rate.
Thank for that
I could go back to the original write over files but the telemetry data gets messed up.
