Ruby
Hi All
I have a 2011 GSA with 16000 miles
I purchased the bike with the AF-Xied already fitted (the chap said it had only just been fitted and needed a few tanks of petrol through the system before it'd make any change).
So, I have recently started to notice (over the last 30 miles or so) a engine vibration at 2500-3000 revs. I first thought that something was coming loose and rattling at a certain frequency.
Probably reading too much into this vibe I first thought it might be the fact I'd put too much oil in for topping up (although it isn't above the red circle).
Then I thought it might be the crappy supermarket petrol that I've had sitting I. The tank over the winter :-/ so I topped up with super unleaded.
Then today I thought it could be from when I recently changed a battery to one of those odyssey ones and I might have forgotten to put the ground wire on the battery terminal when I replaced the battery. So I just checked that and it is blinking away when I turn the ignition on, there's no loose wire dangling about. So as it's flashing away and I can't really remember if there was a terminal on the old battery or not I assume it is grounded to some other point on the bike chassis?
So I should imagine that it is working ok?
That then brings me back to the vibe.
Is it indeed a normal noise of the bike. I have to warm you I'm new to the GS and it's air cooled boxer engine. I've had the Jap inline fours, V twins and V fours.
So am I infact worrying about nowt or do I need to now change he setting of the AF-Xied from its current 7 blinks? :-/
Any help to stop my possible needless worry appreciated.
Richard
Richard
