After spending a wonderful evening fitting my new lights, and ensuring they worked.
using them for no more than 10 mins operation on high beam
Rolled the bike out this morning, prodded the starter button, and all i got was a clunk
Tried again, and the same... FFS
Grabbed the jump battery and hooked it up, gave it 30 sec, and pressed the tit.
Span straight into life.
Ran it to work, all seems ok, although the idle did have a bit of a flutter when i stopped
It was a cold night, with temps near on freezing , so yes that could be a factor.
But..
Brand new battery - 3 months ago, not top of the range, but nevertheless new
Starter has been stripped / cleaned and brushes ok
Additional +ve to battery direct
Additional -ve to battery direct
No other indications of problems...
Before i go and spunk £100+ on a motobat or Oddesy
Any thing else that could be the cause of this battery problem?
I was thinking of hooking up a meter and seeing what current drain is comming off the battery..
Would the new LED Lamps be causing it?
Mart
But..
Mart
