Anti-Pinch Pin arrived today so got that fitted with the Squire Padlock designed and modified to fit the 19mm chain.
I bought some black 10mm thick neoprene foam, which I cut into an oversized disc which now sits between the pin head washer and my wheel. So although you can't see anything in the picture, the 10mm neoprene foam is pressed against my wheel paintwork rather than the steel washer (washer also stops the wheel nuts being undone).
I know the chain should be off the ground (but I need to be able to move around the bike in the garage, if the ground anchor is nearer to the bike it becomes a trip hazard when moving the bike), and this is the last line of defence, so if they've got this far, lots of other things have failed or been breached (and I'll have some interesting conversations with some companies).
I had my 13mm Pragmasis chain unused, so I thought I'd wack that on as well. Doesn't take long and it'll just be a pain in the arse for anyone trying to move it (except me).
Looks pretty awesome, how much for anti-pinchpin, chain and lock?
