It's clearly the repair that's failed...
"Blow out"??
Modern tubeless tyres don't "blow out" unless severely damaged. If severely damaged, puncture seal won't do a thing.
At speed, a punctured tyre may lose all pressure yet still feel reasonable.... However, it will be overheating and possibly delaminating.
Check tyres and pressures regularly; tps is a better safety feature than ABS (imho).
Puncture seal is the equivalent of an Elastoplast.
What Im getting at is, if running tubeless, check tyre pressures and tread condition regularly. Embrace tps. Avoid puncture safe/ seal/ snake juice.
Sent from my GT-I9505 using Tapatalk
Ultraseal no problem with tps ��
This is one reason why I use Ultraseal/Puncturesafe. It wont stop a hole big enough to cause a rapid deflation, but it might give me a few for seconds of riding time before the shredding tyre throws me off in the fast lane.
I'm interested in this and I've looked at the Ultraseal site with a view to getting some. But I'm unclear why the sealing fluid doesn't clog up the valve? Or am I missing something?
I thought the same. But when I read the Ultraseal site info it says the entire inside is covered. So my thoughts the lead to the valve.I'm presuming that an element of centrifugal force is helping the sealant to go whare it's needed. The valve is the opposite way. JJH
