Hunda Dump it!
that's from 10 years plus worth of advice of working on these systems!
If you can't afford a new system and more importantly remember to do annual Fluid changes?
Dump IT!
My most scary "fault" was trying to get a K1200 LT to recreate an owners fault while I was at the dealers !!!!
It LOCKED the front wheel up at 30mph Full servo power and No ABS Only my "scrambling" experience saved me and the bike going down
I fucking hate them with a vengeance I love the ABS but the residual braking is a farce and those who designed it should be tied to a remote controlled motorcycle with their bare arses in the air (a good lashing o cat of nine tails for good measure of course!) and sent off with a faulty controller!!!!!!
ABS II Was pretty damn good and at least left you full power brakes "IF" it went faulty!
The range of faults are quite wide too I did a brake fluid change on a bike that had not had fluid change in 65,000 miles !!! I Was careful not to extend the normal range of levers usuage but 6 weeks later residual braking yet it was top of green band on bleed test etc etc In Fact heres a couple of pics of the fluid!
300 cc in the jar 150 in the plastic bleed bowl Just was going clear at the first third of the third bleeding cup and I bled it on through till the tube was pure fresh Brake fluid
Dump IT!
