oddshapedballs
Evening all,
Need to know if I have an issue or if I'm worrying about nothing.
Noticed that I have, in between the tread blocks on my rear Avon Trailrider, a cut/split approx 0.5 of an inch in length (horizontally) looks like I've gone over something or it's been cut by some twat with a stanley. Anyhoo, I pulled it apart a bit with a tiny flathead screwdriver and can see the wires, the split is fairly closed up and I've inserted some glue to keep any water out.
Do I need to replace the tyre, is it likely to split further with use? The tyre isn't leaking any air.
Cheers.
Cheers.
