Nope... Both are 101mm bore but the 1200c is 73mm stroke vs 70.5mm for the 1150
Superbikes tend to be 'over-square' meaning the the bore is larger than the stroke, so the piston doesn't have to travel far to generate the same swept volume as a longer stroke engine. The further the piston has to travel, the lower the maximum rev ceiling which limits the power output. The higher an engine can rev, the higher power output it can generate.
This is anathema to a cruiser which is intended to be a lazy, relaxed experience. Long stroke engines like those in Harleys, have exactly these characteristics which is why they are suited to the role.
A slightly rambling explanation, but I hope you get the gist...
