It was just loan bike for the day and they were my observations - I just switched the modes using the mode button and found that even in dynamic mode it wallowed a bit on fast sweepers and generally felt overly soft, even dynamic mode - however if there is another entire range of adjustment with the code plug in then I will try to arrange an extended test ride so that I can check it out.
Let us know what you find? My reading of Dynamic Pro is it's an option which allows user-configurable defaults for engine mode and DTC - you can't adjust the individual settings away from those it leaves the factory with.
Wallowing in Dynamic damping mode? Blimey! That's not my experience and I'm not exactly a mere slip of a boy. Are you sure the tyres weren't under-inflated?
