I agree with fred!
I would have agreed on a specific bike set up for you.
But having now experienced electronic suspension, I love it.
Its not a distraction at all.
Get on the bike (are you solo, carrying pillion or luggage)
Set up ride height with a button (if you have to).
Is it raining?
Set up Rain, Road or Dynamic (if you want to)
Then set off on your ride.
The only other button, which isnt a distraction but a bloody godsend, is adjusting between Hard, Normal or Soft on the fly as you ride.
Really nice to flick between lanes (soft) and twisties or carriageways (hard)
Its ace.
The suspension is very underdamped in road setting and overdamped in dynamic, it seems that BMW removed one of three damping settings that were there before.The setting they removed is medium damping. If you push on hard in throad setting ig does seem to firm up a bit, but not enough.
I have just come back after doing 1500mls enjoying the D roads In the Sarlat area, I was constantly jumping between the two damping settings trying to stop the bike from skittering across ripples in the tarmac that my old GS would have ignored.
The suspension is a big step backwards in my opinion.
I agree with this. I have owned many GSs over the years, and all of them (particularly the water-cooled versions) have felt agreeably sporty either one or two up. The latest model (mine is a Rallye Sport) seems to pogo over bumps and is more upset over broken or rippled pavement than my previous 2015 model. Definitely a retrograde step.
After reading this discussion, I guess I need to test ride one of the new ones with the plug in place and see what the fuss is about.
However, when I got my 2013, I was kind of expecting that at some point BMW (or an aftermarket solution) would enable customization of the damping settings for fine-grained changes to the rebound/compression/preload, but it never happened. The fact that they're now going backwards to simplify it even further (like the XR settings) seems like a real dick punch. Good news is it really lessens the temptation to upgrade.
I agree with me
The only issue I can see with electronic suspension is when it fails.
A) will it still allow you to hobble home with everything else functioning? Or will it just shut down for full recovery?
B) how does it fail safe? what mode will it default into?
There is no failsafe setting, it stays where it fails, it could fail rock hard or (as mine did) lose the lower third of the preload/damping range so that in normal and road setting with solo rider, me 11.5 st, I was grinding the pegs. I was able to up the settings for me to ride but no good for two up.Very good questions! I would like to know the answers to those too.
Or not
The change in spring rate is facilitated by two springs switches in series. An elastomer element (Cellasto) in combination with a conventional helical spring below absorbs the forces during compression. The radial outward expansion of the Cellasto element is permanently limited by a steel sleeve. On the inside, an electrohydraulic mechanism is used to move an aluminium sleeve. The position of the inner sleeve influences the inward expansion of the Cellasto element and therefore its spring rate. This has the same effect as the use of two springs of different strength. If the inner sleeve sits on the steel spring, the Cellasto element will not function and only the steel spring will work. If the internal sleeve is then moved, it is also possible to vary the spring mount of the steel spring, in other words the "spring preload".
