On a GS1200 no warning lights come on with the flappy valve disconnected or with the servo motor disconnected. There will be a fault code stored though.
Was it the ESE-BM1 George?
http://www.bikersdiscountstore.co.u.../healtech-exhaust-servo-eliminator-pd-185.php
Why did you need this?
I ditched using the valve years ago, just took the motor off left the knackered stuck wide open valve in place and bob's your proverbial.
Other than a harmless fault code being stored no ill effects, no need for a link pipe, nothing nadda.
A very simple job being turned into a marathon exercise but, I guess not everyone can get along with the KISS technique though.
With regard to KISS , maybe bmw engineers need to look at this , float strip for starters followed by rear wheel bearings , double sided swing arm was never a problem
The simple fix is a piece of stainless tube and let the ECU store it's fault code.
The valve can be dumped into tin of diesel fuel and ignored. It should free-off over a few months and could be put back on the bike if it needs to be returned to standard.
And, do not discard the tin of diesel fuel as you will doubtless require it again
After replacing flappy valve on my better halves bike
2011 bike so had to cut original exhaust bolts off, but ordered new ones from motorworks yesterday. Is there’s still the eliminator pipe of choice?
The motorworks one is the best option, I've recently fitted one to my TC RT having fitted these before to other bikes, no sweaty hammering or swearing needed they pop in with a firm hand and the quality it spot on, they're also made to fit properly so you get one smooth tube rather than a big-smaller-big result (if you see what I mean).
