2017 R1200GSA LC
The EZcan is plugged into the canbus & the canbus is plugged into the EZCan. Wires are routed to the battery though not yet attached.
I now have the 4 outputs available.
I have a pair of LED Spots that will be getting attached to the bike once the brackets arrive (Mon?) they, will be wired direct to the EZCan on the orange connector as in the video on the Hex website
I also want to install a replacement horn - I've gone for the split Denali Soundbomb
I've figured out where I'm going to fit the two main component parts of the horn.
My question is this... do I now run the pos/neg wires from the new horn to the EZCan red connector, leaving the stock wiring blanked off & stowed away, or do I use the existing wires?
