dippy
Hi Folks,
Went for a ride the other day and after 300mtrs engine cut out, restarted OK, I didn't notice anything unusual on the dash although i didn't look drove off and 100mtrs later engine died again and this time I noticed EWS and no gear showing.
tried a different key, no luck. tried a different antenna ring no luck but playing around with the antenna ring all of a sudden bike sparks into life for a second then dies again. closer inspection of cabling leaving the antenna ring showed what could be a loose connection.
So, replaced cable as far back as i dared to go but still the same although i only twisted the wires together. Checked that the right wire goes to the right colour about 1000 times.
any ideas folks before i send to the garage?
Thanks in advance
Thanks in advance
