@skid06;love your bike !
I got 2 questions for you.I have a 2017 GS-ADV and also the Ohlins TTX setup.Does your yellow triangle (ESA fault) light up like mine does and if not what did you do ?
Do you run into lean angle issues having lost 1 inch ground clearance on the front with the 17 inch front wheel ? What spring rate do you run on the rear.I got a 170 and still feel it is a little soft.My weight is 215 fully dressed up.Thanks !
Otherwise I'm like you.I love the S1000XR which in my opinion is the best street bike period when it comes to the triangle power,handling,practicality.
If it only had TL and driveshaft.
I really want a GS with 150hp and 17 inch wheels right from the factory...
