fred_jb
Just got back from the dealership after having the hill start , retro fitted to my March 15 GS . Well tried it at the first set of lights on a slight incline, it took a couple of attempts to release it, but I didn't stall it. It made me realise that I needed more practice,so set off for a steep hill on an abandon road. First attempt stalled it, second attempt squeezed the front brake until I saw the light come on the dash, then released the brake, and it held perfectly, then lightly pressed the back brake , then a quick squeeze on the front to release the hill start ( light goes out on dash ) and pull away as normal. Tried it a few more times, and that method worked ok for me. If any body has another way, I would like to try it.
Price in Spain was Euro 303. 36 plus 21% Iva total Euro 367.07.
Expensive I thought., was thinking around the 250 ish mark.
I think the idea is that it just auto releases when you move forward, like an electronic handbrake in a car, so in theory no need to manually release and switch to the rear brake before pulling away. However, having tried it a few times, I've found that you need to use more revs than usual when pulling away or you can stall, and a couple of times I've ended up repeatedly pulling the clutch to avoid stalling, putting me into a nasty stop/start cycle until I finally got it to release automatically. Obviously needs decisive and fairly heavy application of the throttle when starting off, which doesn't come naturally to me, so I will have to find somewhere quiet to practice. In the meantime I've decided to release it manually as you are.
