Battery Discharge
Your multimeter is set to amps but 20milliamp max range so your reading is 0.18 amps thats 180 milliamp = too much.
When you put meter in series with the negative battery lead the meter goes crazy as the ecu is powering up and waking up and its only after about 5-15 seconds till the readings will stabilise, this is normal.
Check the positive battery lead is clean and making good contact tight with the battery, as dirty leads cause resistance that causes current drain.
I note you run the bike for 15mins, after using the starter you will discharge the battery significantly and a run of at least 5 - 10 miles would be needed to recharge what you have taken out. Running the bike at tickover
does not charge the battery sufficiently.
A sealed lead acid battery loses 1% of its charge daily whilst not being used, if a battery is left in a discharged or partially discharged state for too long, the plates inside "sulphate" then the battery no longer has its full capacity when recharged.
Check charging: voltmeter across battery should read 13.5 to 14.3 if charging correctly with engine running, ensure volts dont drop below 12.8 when lights on etc and above 1400 rpm. If not charging correctly
this shows alternator / regulator fault. You should see the voltage change as you rev the bike gently from tickover.
the drain of 0.18 is higher than i would expect, (0.056 should be about right without alarm or tracker powered up and if a satnav is fitted with a usb charging lead disconnect this as many are permanently live at 5v for charging phones etc) you disconnected the tracker, next i would check the alarm is switched off or disconnect it, also look for the bike wiring diagram and look for the charging circuit, the diodes in the regulator maybe failing, to isolate this you may need to disconnect the positive wiring to the alternator. ( if diode pack / regulator is inside the alternator) But do not start the engine with the alternator wire or wires removed, you will burn it out. Some bikes have either a relay or solid state device that switches charge to the battery, sometimes these can stick on draining the battery. (Diode / regulator pack) so if this is separate disconnect it and check battery drain WITHOUT ENGINE RUNNING ONLY) A process of elimination to find the current drain is required.
trickle charge the battery every 7-10 days overnight using a canbus friendly charger such as an optimate. then your battery should have at least 2 years lifespan.
starting a bike with a starter and running for 15 mins is no good for the battery. You are draining more out of the battery than what is being put back in. doing this regularly flattens the battery, not regularly charging it, ruins it. see https://www.batterystuff.com/kb/art...s/secret-workings-of-a-lead-acid-battery.html
0.18 x 12v = 2.16watts its too high ! Power = Amps x Volts so 0.18amps = 180ma so 0.18 x 12 = 2.16 watts
Batteries that are not fully charged, if discharged much below 11volts upsets all of your ecu settings as well, making bike even harder to start as all the settings are out, likewise fitting accessories like
heated clothing can demand too much from low capacity batteries, that inturn the volt drop upsets the ecu settings resulting in poor running etc. ( info given to educate others)
regards Steve
regards Steve
