dunnie
Time to deal with some more issues before organising anymore continental excursions {last time we rode back to England with no clutch from Paris}.
So two issues that need addressing, firstly my gear shifter seems to have an excessive amount of play, it works perfectly but the shifter has alot of free movement on the locating shaft. Does anyone know if I can replace a bush or washer or do I need to source a new shifter? Ive not had the time to strip it yet so cant say that I have identified what might be well worn, if anything at all.
Secondly my front master cylinder has given up the ghost and all the fluid has leaked from the mater cylinder. I have found there is a youtube video where someone has replaced this but is it worth doing or should I source another master cyclinder from elsewhere. The repair kits are about £50 which isn't too bad if a permanent repair is achieveable.
Any advice would be greatly received, kindest regards,
Dunnie
Dunnie
