The cast wheel bolts are about 10mm shorter that the wire wheel bolts. If you fit the longer bolts to the cast wheels they will foul the wheel carrier.
The later type front discs with older type cast wheel will not properly fit the front callipers. But I have the early discs with early cast wheels on my GSA and they fit fine. so like for like seem ok.
