Hi All.. just a quick one... I've been looking at my front tyre today and can see I've got a nice flat in the middle from the motorways, but I can also see where the flat hits the rounded bit of the tyre, one side its a radius, but the other side is a much sharper radius... Any thoughts on this?.. can't see any adjustment anywhere on the bike?.. checked back wheel to front when perfectly level (both back and front are spot on with a spirit level on the discs)... using string spaced on the front discs to give the same widthe as the back wheel... I then ran them string to the back wheel and tapped it on. measuring over 500mm of the wheel front to back, I had a 1mm out of alingment to the front... I'm sure this can't cause it.. let's face it, there is only 50mm hits the road so 0.1mm there? so I'm thinking this is as good as it gets...
Any ideas?... back one looks okay??.. Cheers
