I may as well be the one to mention it as someone will need to eventually
It is advantageous to heat the retaining bolts up to release the loctite
type stuff holding the bolts and, ensure the tool you use is a very good fit into the bolt head as it is quite easy to
strip it.
Another bit of good advice is to obtain new bolts before you do the job.
