A bit of a generalization if you don’t mind me saying so. How are you aware? By your own admission you have found nothing definitive. I have a 2017 GSA and have not found the trait you describe.
It is admittedly, a big bike but I’ve always found it rock solid in all situations. It does take some getting used to after other bikes- as an example, it’s about 5 stone heavier than my previous 2011 twin cam GS and the C of G is higher as a result of the greater fuel load. It is very stable at low speeds and the clutch is smooth and allows non snatchy feathering at low speeds when needed. I will admit that I’m 6’5” and 20 stone so maybe I’m ideally proportioned for the bike. I will also admit that I tend to put some time into practicing low speed manouvering with any new bike, to get a good feel for it so it becomes second nature.
Try an extended test ride - you may be surprised by how the weight disappears when on the move.
Alan R
Many thanks for all of your replies, they are all useful to read. Sorry that I’ve not been able to respond until now, but I’ve been busy with all sorts, including organising a test ride of a lowered GSA.
It seems that opinions vary with regards to whether it makes a noticeable difference. Thinking about the physics of it, dropping a 263kg bike a few centimeters has to have an effect on its CoG. I just didn’t know if it’d be that noticeable, although some say yes, others not. Well I’ve organised a test ride on one for next week so I’ll be able to compare it to mine. It won’t take long for me to notice if there’s any difference, so should be a quick decision.
Maybe I should have clarified that I currently own a 2014 GSA (obviously LC), which is standard height, and have no issues with being able to get my feet to the ground, nor have I had any ‘nearly’ moments.
Alan R, I wouldn’t really call what I’m talking about a generalisation, I’d say it’s a characteristic of the bike. It’s likely that your interpretation of my zigzag description may differ to mine though but, to be fair, I didn’t describe it in great detail.
It is something I have personally noticed, and something that others have also noticed and voiced. I’ve even watched video footage on YouTube and heard it mentioned. To be clear, I’m talking about very slight steering adjustments to keep the bike in a dead straight line, but as I said in my original post it’s only at VERY slow speeds. Yes, I know... it’s not how we ride, but to emphasise the point, I’ll bet that you can’t let go of the handlebars for very long on a standard height GSA moving at 5mph for very long! Gyroscopic stability vs weight of bike... Not many bikes would continue for very long if you did this, as they’d require constant human input to compensate for the lack of balance due to no gyroscopic effect from the slow turning wheels. Some bikes I’ve owned have been almost like pedal cycles, where they remain stable right up until stopped, which is just down to a well balanced bike. I’m not mixing up the balance of the machine with balance of the rider. Dougie Lampkin springs to mind here...
Once the speed increases, even only a few mph more, it quickly becomes much steadier. I’ve ridden a few GSA’s (all standard height) and it’s something I’ve noticed on all of them, so it’s not that my bike is faulty. Just to show that I’m not faulty either; I’ve been riding motorcycles since I was 9, I’ve raced, do track day instruction and, yes, for this post only, advanced police rider (lock stop to lock stop turns were a major requirement). And, I used to play ice hockey, so can balance quite well too.
The only reason I mentioned the steering at slow speed is because others have mentioned it too, and the rider of one review, of a lowered bike, I saw stated that he’d noticed that it didn’t tend to wander at very slow speed as much as the standard height bike! I was simply just curious to know if anyone else had noticed the same? Ultimately it must be something to do with gyroscopic stability vs weight vs CoG.
Obviously, most motorcycling tends to happen at higher speeds than the ones I’m talking about, so I’m was interested in how the lowered CoG affects general riding and cornering.
Agree re clutch, it’s superb!
I suppose my test ride next week will answer my questions, but it’s still interesting to know what others have found.
Regards
Ash
