Cyclistbruce
ABS light is intermittently flashing, checked the fault code via pin 2, it's reading as rear ABS sensor (4 flashes). Figured I damaged it when I had the drive shaft off.
Checked the pins inside the sensor plug on the multimeter which showed no continuity. I bought a used one, and this didn't work (tried resetting the fault but it persists). Also no continuity on this either.
Dealer sent another sensor, still no joy. Also no continuity across these pins. So am I missing something here? There should be continuity across the pins right? Can't believe I've got 2 duds in a row!!
Sent from my SM-G950F using Tapatalk
