Yamaha XT 500
g.s.john
Getting old aint fer pussies
slade green kent
I have just acquired a 1981 XT 500 with 6 volt electrics magneto ignition and a right bastard to start I thought all that disappeared in the seventies :rob
I have been looking on rexs-speedshop.com and a 12 volt conversion is mostly plug in to replace the old units also electronic ignition also fairly straight forward.
Any advice on how to make life a bit easier with this old beast.
ta
I had a nightmare starting mine years ago, after months of diagnosis, turned out it was a break in one of the three coils on the stator plate. Started first time every time after that was fixed.
I have a 1980 model, it was very susceptible to condensers but once it had a new one fitted and the points set correctly it was ok to start. I have now converted it to 6volt electronic ignition and it is now a lot more consistent to start.
So remember that! It was in the days of more time than money, I cut out the offending coil and I rewound it :eek:
No internet, online spares :rob even made a bobbin to facilitate the rewind!
From what I remember, they've always been a bastard to start.
I used to live with a girl who had an XT550. I used to spend half an hour kicking it over before we needed to set off.
Unless you are a purist and want to keep the bike totally original the move to 12 v makes a lot of sense.
Better starting, lighting , smaller gel batteries etc. Remember if you do switch its the little tings like speedo bulbs and horn you forget to change.
Have look at www.rexs-speedshop.com they do the complete kit with bulbs and battery might go down there to have a look.
Not right or typical of the 550.
It must have been out of tune or the decompressor cable was incorrectly adjusted.
My XT550 is a 2nd or 3rd kick starter every time.
You are probably right. It was a bit of a shonker.
Went to rexs speed shop at Robertsbridge to get the carb serviced and cleaned and get a few bits I am going to get the 12V/electronic ignition next month, why is there always more month than money?:blast
When I first had mine (1978 model) it was difficult to start. I fiddled about with the carb and air filter which had been bodged, may have fitted a new plug but with regular use I found it became easy to start. I think there is a knack but obviously everything need to be in good tune. I never had any issues with the magneto, never had a battery fitted.
How does it perform with a 12v system?
Don't know yet it's all set up and new tyres ect but I have a leg infection and can't kick the bloody thing over.
Ok leg infection is sorted, bike started second kick runs nice but the revs rise on a closed throttle the throttle quadrant is not sticking I suspect the diaphragm might be the cause?
any ideas?
Maybe a slight leak on the carb intake rubber.....
