Ducati 250 Desmo Rebuild
Last thing for now, I checked the disc run-out with a dial gauge, I wasn't at all expecting it to run true but it's pretty good, I'm certainly not making any adjustments
<iframe width="560" height="315" src="https://www.youtube.com/embed/aVhaK5GATYM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Nice job :thumb.
I've been using one of those Mopod flaring tools for years and find it extremely good - far better than some of the other designs out there.
Bob.
I last used it to completely re-pipe an old Mini 20+ years ago Bob, I’m surprised I could remember how to use it!
Lovely job on those pipes - it’s the disproportionate amount of effort that goes into small details like that that makes a build both fun when you’re doing it and so satisfying when it’s all done :)
Andres
And that’s when I found many of the rocker cover screws were seized and the chocolate allen head screws were rounding off :blast
Best plan seemed to be to tap a Torx bit into the socket head and use that to turn the screws out :thumb2
First thing was to make a torx bit fit in the 5mm allen head bolts. I ground an oversize torx bit so it was a very tight fit when hammered it to the screw head, I sacrificed some allen bolts off the bike to make sure it all worked ok.
This is the kit I used from the 1/4 drive Halfords socket set. I made sure the torx bit was up to the job by fixing it in the vice and giving it a few clout's with a hammer. I didn't want a shattered torx bit stuck in a screw :thumb2
This is the first screw out, tap the torx bit in and they come out quite easily. Btw, penetrating fluid made no difference at all.
This is the only screw that beat the torx bit, it was already well rounded with nothing left for the torx bit to bite on, it needed drilling out :eek:
I experimented on old screws how big a drill I needed to nip it off and how deep to drill.
The cover came straight off but the screw head remained tightly stuck in the head and had to be drifted out from the back using a drill as a drift.
I'd stuffed a rag in the hole before scrapping the gasket off
As things were going so well I decided to do the screws for the bevel drive and cam cover. You can see new screws in the rocker cover.
Upper bevel drive. The wear pattern on the gears looked very good, it must have been well shimmed up at the factory
After all this there was clear signs of fresh oil comming up from the sump. Anyway, I pumped loads of oil into the valve gear and bevel drive before closing up :thumb2
That it for now!
First start up after 45 years, this is my mate Dave doing the start as he has magic boots and I wanted to film it. That puff of smoke cleared instantly, it was just some 3in1 oil I'd put down the bore when I first got it.
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZtdBkpRN_ns" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Wooooooo Hoooooooo :clap:clap:clap
Is that it now, anything left to do?
Andres
It still needs MOT and re registering hopefully with the original reg plus a few odd jobs. I’ve ridden it up our street and the engine and clutch seem very sweet. I can’t as yet get any of the gears above first as I haven’t trained my feet to twist up that far, this maybe a problem, we’ll see
Great stuff.
I was there for the first fire up of my father’s totally rebuilt Frazer Nash after about 60 years. A very different project, I’ll admit but the happiness is the same. I am sure that in 200 or more years there will still be bods doing stuff like this; who knows, maybe with the same bike?
Weeeey Heeeeey ebbo !!!!......I have been waiting for that video for yonks....:thumb2 :thumb2 :thumb2
What a cracking little bike. I know that you've outsourced some bits n bobs, but the whole picture is a credit to your your skills.
Very VERY well done Sir.....:)
Thanks everyone, I did outsource a lot, looks like I need to outsource the revcounter next because as soon as you rev up the needle dances all over the place :D
I’ll post up anything more I do with it but it’s just about done now :thumb
Brilliant Ebbo
This has been one of my must view threads, thanks is for letting us into your build world.
You must be so chuffed :friday :friday
