Handily there's a switched spare power supply under the saddle on the KTM. Doddle to wire that in...
Well that's a disappointment.
I tried twice to upload my RAW 360 footage to my new laptop in 5.7K and it failed. After 4 hours each time. I had two files, one being 35 minutes long, and the other being 1 hour 35 minutes. Both failed.
Don't know why, so I'm going to have to experiment more and try and find out whats going wrong. Bad news is I can't upload any of the footage from today so I reformatted the card in frustration, and will have to come back to this again.
I'm also not impressed on how long 5.7K footage takes to upload onto my new laptop. Using USB 3.1 ports and a U3 Class 10 A1 MicroSD Card (it's a 100mbps read rate), so it's fast.
Samsung also do a new SD-II card which reads up to 275 mbps but its £200+ just for the memory card.
Might have to stick to the standard 4K stitched setting, as at least I get the footage onto my laptop easier....
Cameras
Mobile Phone
External Storage Device
Damn good research
Its actually a complete pain in the neck.
The issue I'm going to have is...
A) What to record?
i) Everything and then edit later?
ii) Limited recording but risk missing an 'event'
iii) Mash up, bike cameras on all the time. 360 helmet cam only during special moments.
B) How to store all this data and keep it simple and time friendly.
i) So I dont piss everyone off faffing with camera tech instead of enjoying my adventure.
ii) So its easy set and forget
iii) Reliable with minimum points of failure.
C) Keep the costs from going ballistic
i) Finding a sensible compromise with existing tech we've all got
ii) Not carrying £1000's worth of vid processing equipment.
iii) Make it work without to many compatibility issues
My Anker USB 3.0 Port arrived today.
So I had a chance to set it all up.
The idea being, this is all you need to transfer video files onto mass storage while on tour. It'll keep your camera memory cards free each day for fresh recordings. Using the Anker Port means you don't have to keep trying to access the Mobile Phone MicroSD Card Slot, which is fragile.
1) USB Adapter for your Mobile Phone
2) Anker USB 3.0 Multi Port
3) Kingston MicroSD USB 3.0 Card Reader
4) Seagate Expansion 5TB Drive (Powered Independently)
5) Mobile Phone
So now I can use my phone screen and see the 5TB Storage and move files off the camera cards at the end of each day.
It's quite compact setup and doesn't need a laptop.
Mate you should get a camping car, far less hassle
It's only hassle when I'm at home, not knowing how it's all going to work.
Once I've figured all this out, when on the road, it'll be lightweight, easy and no trouble.
If it becomes trouble, It's still lightweight so I'll just forget it and carry on with my riding.
I'm hanging on like a dog to a bone because in the next couple of seasons I'll be doing some 'once in a lifetime' trips. So want to record it.
Ok, it works.
I filled a 128GB MicroSD memory card with Virb 360 video footage at 4K Stitched (which technically is 4K, but video resolution is only 1080p at best).
Installed the memory card directly into my Samsung S8 Mobile phone MicroSD Card Slot and then connected the Seagate 5TB Expansion drive to the USB C Port.
From the phone screen, using My Files, I could then transfer the data from the MicroSD Card directly to the Seagate 5TB Expansion drive.
128GB of data transfer took 1 Hour 8 Minutes.
What I want to do next is get a USB 3.0 Splitter so I don't have to repeatedly install the MicroSD Cards in the phone (it's to fragile for repeated attempts). That'll give me a simple way to transfer the data at the end of each day
I’m interested to know How many hours worth of 4K you can you fit onto a 128gb card please.
The internal battery is 1250 mAh which supposedly lasts around 1 hour at 4K filming. Some people that will be enough, maybe with a couple of replacement batteries?
But I know that I never remember to charge multiple batteries, one is enough, so I've bought the Garmin Tripod Power Mount which has a waterproof cradle that the Virb 360 unit sits in, and then a 2 meter USB power cable to feed off.
I'm then going to plug that USB cable into a 20,000 mAh waterproof, shock proof battery supply which should last at least 5-6 hours if not more. The cable is split about 12 inches from the cradle with a waterproof screw fixing. So in theory, I can put the helmet on, and then screw in the cable connector which then leads into my back pack.
I know the Nexx XD1 helmet has space for a battery pack inside the helmet, but I'm not convinced that's an idea I like?
So I'll see how it goes first.
Been reading this thread with interest, I dabble a little toe with a drift camera, nothing more, but would like to avoid having to swap batteries so often, the powerbank and usb cable is interesting, especially the usb cable to IPX7 with a screw connector, where did you source this?
ta
Its a Garmin 360 Cable Option. Power to USB
