Lights powered by EzCan
I have Denali D2 and DX lights spliced together and the Ezcan handles it just fine.
Its 10 amps on 1 & 2 channels for the lighting so 10 amp x 12 volts = 120 watts per channel [max]
On channel 3&4 its 4 amp x 12 volt = 48 watts max per channel
Is it possible to run spots at 10% for daytime and 100% for full beam with the ezcan using any LED SPOTS ?
You can adjust the slider for the standard setting and thumbwheel to alter on the fly as you ride it does not pick up if you are on high beam ,it will return to standard setting once the bike is turned off
